stroker kit
Old May 29, 2014 | 01:40 AM
93transambadboy's Avatar
Default stroker kit
Sorry to bother yall guys with a question yall have probably answered a million times but where the f'n f can I find a quality stroker kit for my lt1 I have googled it hundreds of times rewording it every time and all I can come up with is some junk a $$ eagle or no name ebay kit please post links thank you
Old May 29, 2014 | 01:42 AM
And my plans for it would be to build a street/track 500rwhp car le3 custom grind cam probably nitrous
Old May 29, 2014 | 05:29 AM
bufmatmuslepants's Avatar
Just go with a forged eagle or scat or compstar or Ohio or Howard's crank and quality 1.5/1.5/3mm ring pistons from Mahle or diamond or weisco or JE that are -5cc if you are staying NA, forged everything only, NO CAST CRANKS. You are most of the time better off picking each piece separately, but any 1 piece RMS chevy small block kit would work, but make sure to use the newer thinner mm ring packs, not standard, and aim for 11.5-12.7:1 compression with 0.032-0.040 quench, talk to Lloyd honestly.
Old May 29, 2014 | 06:31 AM
moehorsepower's Avatar
OK, Here we go, 500 RWHP without nitrous, do you know what it takes to make 500 RWHP N/A?, Like said, just get with Loyd.
Old May 29, 2014 | 09:32 AM
jaycenk's Avatar
talk to Lloyd and advanced induction. Gonna take one hell of a head and bottom end most likely not stock casting head maybe brodix, trickflow and CNC worked and a really good tune.
