Slow starter
Old Jun 3, 2014 | 07:41 AM
GhosT5's Avatar
Default Slow starter
So I'm gonna start working on my 93 Z soon, when you start the car the starter starts spinning very slowly and then it gets going and spins the motor fine. Once that happens it fires up in like a second. The motor has no bad noises as far as I remember, so I doubt it's anything in the motor. Is it probably a tired starter or could a bad battery/connections be causing this? The car was sitting for good 6 years now, the battery is completely shot.
Old Jun 3, 2014 | 07:57 AM
93M6Formula's Avatar
Well if the battery is shot that's not helping you out. Corroded connections and a warn starter will also do that. My orginal starter finally crapped out this year, I think the heat from the headers killed it.
Old Jun 3, 2014 | 10:39 AM
19trans79amws6's Avatar
I was having the same problem but i had a new starter and new battery. I had to ground the battery better, put another ground on it and took care of my problem.
Old Jun 3, 2014 | 08:21 PM
GhosT5's Avatar
Is the battery grounded to the block and the chassis stock, or just one or the oher? (yeah, I didn't even have a good look at the bay yet)
Old Jun 9, 2014 | 08:36 AM
GhosT5's Avatar
Well swapped out a battery and it starts right up. Can't say I'm surprised.
