running rich
Old Jun 8, 2014 | 09:25 PM
93transambadboy's Avatar
Default running rich
So my 93 trans am has been running horribly sometimes it doesnt want to idle and the warmer it gets the worse it runs it sprung an oil leak at the timing chain cover so I change the timing chain cover gasket and while im there I go ahead and get the oil pan gasket my accell optispark had a hole in the cover so im like $h!t that could explain it missing and running everything looks to be good on the distributor so I melt plastic to it and slap it all back together I get it running pull it out of the shop and take it around the block making sure everything sounds good temp stays good all that so it check out and I get in it alil bit throttle response is good sucks me back into the seat im like hell yeah thats the best its run since I bought it so I get it out on the main road to do some hotrl roddin and it goes right back to how it was when I started which includes poor throttle response missing running rich all that so please if you have any advice at all please share
