lt1 spring locator ?
Old Jun 12, 2014 | 10:07 AM
lehr's Avatar
Default lt1 spring locator ?
Does anyone know the ID and OD stock lt1 aluminum head spring locator, I'm trying to shim my valve springs and the shims wont fit over the locator.
I have comp cam beehive valve spring 26918-16.
Thanks
Pat
Old Jun 12, 2014 | 10:21 AM
BALLSS's Avatar
shims go under locator
Old Jun 12, 2014 | 12:01 PM
lt1-xjs's Avatar
Thanks
Pat
Why would you want to shim them ? All lock combo's set them up short as it is.
Old Jun 12, 2014 | 12:04 PM
lehr's Avatar
looks like I'm going to have to shim .100 to get to 1.800 spring pressure height. Do you think I would be better off with a thick spring locater/cup.
Thanks Pat
Old Jun 12, 2014 | 12:45 PM
leadfoot4's Avatar
Thanks
Pat
The Overall Diameter of the locator is 1.300"
The Diameter of it, at the "step" is 0.890"
The inside diameter is 0.580"
Old Jun 12, 2014 | 01:40 PM
lehr's Avatar
Thanks leadfoot.
Old Jun 12, 2014 | 03:34 PM
leadfoot4's Avatar
Thanks leadfoot.
You're welcome!
