Temperature (sending unit?) Issue
Old Jul 7, 2014 | 10:43 PM
BigBadWhitey's Avatar
Default Temperature (sending unit?) Issue
Hey guys, problem just started with my 1997 z28 today.
The car will come up to temperature and runs just fine, then while driving (mostly on uphill or under half decent acceleration) the temperature gauge will just peg itself out, full hot. It will return to normal usually really quickly, or it will flicker up and down with acceleration/decell.
Any ideas? Im not too sure what this would be symptomatic of, or if its safe to drive the car.
Old Jul 8, 2014 | 08:58 AM
shbox's Avatar
Might be the wiring, connector or the sensor or could be you have some air in your cooling system.
Old Jul 8, 2014 | 11:01 PM
As far as air goes, is there anyway a toast head gasket would contribute to that?
Its a boosted motor (barely, only has ever made 3psi) but the jumping around seems to be under load. If im pointed uphill and give it throttle (gets down to 14mmHg) it flickers, if im pointed downhill and give it throttle, nothing, until i let off.
Very confused, not sure where to look. Going to go try the grounding method now.
Old Jul 9, 2014 | 01:26 AM
Tested the grounding method, noticed a piece of the wire wasn't under the cover. Taped it up and covered it, all good now!
