94 lt1 carbed setup help
Old Jul 12, 2014 | 12:08 AM
exrex0015's Avatar
Exclamation 94 lt1 carbed setup help
im converting my 1994 camaro with 4l60e trans over to carbed and i have a few questions
#1 can you just leave the opti where it is and not worry about a cover
#2 what wire do i need to hook up to the rear of the distributer to feed the RPM data over to the stock computer in order to shift the trans
#3 what type of fuel setup could i use im looking to keep the stock pump and use a fuel regulator with a return line but cant find one to hold up to 100psi down to 9psi any segestions motor built just need to wire and solve trans problem and fuel problem
Old Jul 12, 2014 | 12:30 AM
guppymech's Avatar
Since you're new here I'll slip you the crippler gently.....read this thread (it ought to be a sticky).
https://ls1tech.com/forums/lt1-lt4-m...hat-takes.html
Old Jul 12, 2014 | 01:39 PM
exrex0015's Avatar
Default lt1 carbed setup help
i have already read that whole thread it does not mention how to trick the factory computer to shift the tranny
