? 95 TA headlight question
Old Jul 24, 2014 | 10:29 PM
95TAVERT's Avatar
Default ? 95 TA headlight question
I am not a long time TA owner so There's a lot I don't know. I have a 95 and most of the time when I turn the parking lights on the headlights don't pop up. But now every time I turn the parking lights on the headlights pop up. So with the parking lights on sometimes the headlights pop up and other times they don't . Any help would be appreciated. Thanks
Old Jul 25, 2014 | 12:36 AM
devildog214's Avatar
Its a sign you're headlight gear is going bad. Mine would go on all the time either the intermediate lights or the full headlight, but it would also grind for a few seconds when you turned them down. Easiest way is to get either a new plastic gear, or aftermarket metal gear and replace it and re-epoxy it together (i had to epoxy it once then the headlights started acting up again because the epoxy had failed and i had to use gorilla glue instead and has held up for over a year.)
Old Jul 25, 2014 | 08:47 AM
95TAVERT's Avatar
Great that makes sense, my motor started growling bout same time, I just didn't put the two and two together. Thanks for info.
