ARP studs, ARF heads... Torque Specs
Old Jul 27, 2014 | 02:12 PM
OVA1's Avatar
Default ARP studs, ARF heads... Torque Specs
Anyone know what the torque values are for ARP studs, using AFR heads on the LT block?
I think, on all the other builds, that I made three concentric passes, as described on Shbox's site, setting the last pass at 90 lbs.
I can't find anything on this, and no one in my circle is available, locally.
I'd sure appreciate the input... . Would love to get this done today.
Old Jul 27, 2014 | 05:49 PM
96capricemgr's Avatar
Torque settings are all about the fastener, why are you confusing yourself worrying about what heads and block they are being used in? You look up the ARP spec and that is the end of it.
Old Jul 27, 2014 | 08:49 PM
97 6speed z's Avatar
Post
Originally Posted by 96capricemgr
Torque settings are all about the fastener ...
It's not ALL about the fastener ....... it's about the fastener and LUBE you choose to use.
OP here you go: http://arpinstructions.com/instructions/208-4303.pdf
Old Jul 27, 2014 | 10:15 PM
Puck's Avatar
FWIW, AFR states 70#s and ARP states 80#s. I did 80#. Ova did 80 as well after a PM .
A couple #s either way won't hurt as long as they are all tightened evenly, with the proper lube, and in the proper sequence.
Old Jul 28, 2014 | 12:22 AM
great421's Avatar
80 ft lbs here as well on my ARP studs.
Old Jul 28, 2014 | 09:08 AM
BIGCAT7274's Avatar
80 on my stuff.
