Hard start
Old Aug 20, 2014 | 04:26 PM
superspirit's Avatar
Default Hard start
Well my LTX Blazer is acting up. When I go to start it it will crank and not start, sometimes it will act like it hits on a couple cylinders other times it acts like it;s not hitting at all. after 2 to 4 attempts it will start and runs like there is nothing wrong once it does start. just doesnt want to start normal. is this a common symptom of an opti going out? I have scanned it and no codes are present. any thoughts on this would be appreciated.
Old Aug 20, 2014 | 04:46 PM
nomoneyz's Avatar
Have you checked your fuel pressure?
Old Aug 20, 2014 | 06:27 PM
Going to do that in the morning, but it doesnt act fuel related. also no tach movement while cranking with no start. autometer tach not oem.
Old Aug 21, 2014 | 12:02 PM
fuel pressure was fine this morning, but its starting good. go figure. I will monitor it through the day and see what happens.
Old Aug 21, 2014 | 01:35 PM
Well it's definitely fuel related. pump is slow to build pressure at times and not at other times. going to check voltages and wiring to pump.
