Speedometer delayed......
Old May 30, 2015 | 05:44 PM
hrcslam's Avatar
A little update on this. I replaced the Alternator and while the engine runs smoother the speedometer is still delayed. But, now it'll lag until I hit about 6K RPMs (maybe a bit higher) then JUMP to 7K RPMs and the speedometer will match that jump. Weird. Sounds like a voltage issue.
I'll get a video of it one of these days when it's safe to do it and I won't get in trouble for it. It does this in all gear when I take it to redline (well, first to third anyway I haven't redlined 4th or higher, LOL).
Old Jun 2, 2015 | 09:47 AM
CamOnlyJabroni's Avatar
Originally Posted by hrcslam
I doubt it because it keeps up fine in my data logs. 1-2 shifts happen at 51-53 mph in my data log. But my speedo says 45ish. When my wife was reading the data log and GPS for me I was driving nice. I never throttled it.
She doesn't like it when I drive like an idiot, she broke her back a while ago so it hurts her when I drive aggressively. So I avoid it with her in the car. My kids though, they LOVE it!
Maybe I should pull my IP cluster and replace it with a tablet screen and Tuner Pro RT Dash mode........
What rear end ratio are you running and tire height?
Here is a video of my speedometer and it doesn't keep up. After you let off it keeps going up another 5mph or so. https://ls1tech.com/forums/lt1-lt4-m...l#post18820382
Old Jun 2, 2015 | 01:23 PM
hrcslam's Avatar
3.42 with 26.1" tires (295/35R18) at that time. I'm now running 25.57" tires (275/35R18). Yes, the speedometer will continue to climb after I let off the throttle (sometimes already on the brakes). But My speedometer also stops at 115mph (I have the 160mph speedometer), it will not go past that.
Old Jun 3, 2015 | 03:48 AM
hrcslam's Avatar
Here's that video. You can see it's delayed, then jumps. 1st gear at redline (6700rpms) tops at 56mph, 2nd 83mph. You can see in the video second jumps to 83-84mph at under 7k rpms. The jump started after I installed a new 140 amp alternator. DA was at 3475ft during this run, gotta love dragtimes app! I never hit the Limiter, but I'm sure I got close. No data log for this run to confirm though. It was also on an up hill on ramp.
The last 2 seconds of the video I'm on the brakes and slowing down (after I let of the gas I went to the brake), but the speedometer didn't show this until right before the video ends.
I also notice when the gauges jump the volt gauge drops into the red. Belt slip maybe?
On a side note, you can see my traction issues in first.
Old Jun 4, 2015 | 03:39 AM
hrcslam's Avatar
Default Speedometer delayed......
I think the jumping issue is related to the voltage drop. I did some research on this and found out my alternator is spinning to about 21k rpms at 6700rpm. All my pulleys are stock. This explains why I chucked my last alternator pulley which is why I have a new alternator.
Stock redline limits the alternator to about 18k rpms. The drop looks to start at just above the stock redline limit or about 18.7k rpms.
I'll try a larger pulley in a month or so and update on that. I'm also going to pull my relay box and clean/inspect all the contacts on the bottom and see if that fixed the delayed issue.
Old Jun 4, 2015 | 05:08 PM
savage388's Avatar
my car is stock except gears, bolt ons and I get a delay under wot. my last data log showed my peak speed of 90 when my speedo only read 70-75. It gets worse with speed too, my wot overdrive shift only reads 90 ish on my speedo but actually more like 120. It's just the nature of the beast I think.
Old Jun 10, 2015 | 07:19 AM
ahritchie's Avatar
https://ls1tech.com/articles/ride-on...-white-beauty/
^ Congrats on getting featured in an article..however, according to LS1 tech, your car runs mid 14's @ 96MPH
A misprint I take it?
Old Jun 10, 2015 | 07:30 AM
Shownomercy's Avatar
Man-Crush Warning
Never heard it called running 9s when you only do that in the 1/8 lol
Old Jun 10, 2015 | 02:34 PM
hrcslam's Avatar
Is this a joke? Where did this come from? Lots of bad info there. 9's in the 1/8th, lol that's worse than stock. lol
Yes, bad info there. I had all seasons last time I went to the track (2.097 60 foot), DA over 6200ft, and I suck at launching the manual. But the results were an embarrassing 13.4 at 108 1/4. I forget the 1/8 time and trap, but it was bad. lol
Old Jun 10, 2015 | 02:35 PM
hrcslam's Avatar
Right? Where the hell did that link come from? The car isn't even white. It's primered gray.
Old Jun 10, 2015 | 02:45 PM
ahritchie's Avatar
LOL....yesterday it was the first thing anybody saw on the front page of https://ls1tech.com ....still is right now! It kinda makes all LT1s look slow though...
Old Jun 10, 2015 | 03:04 PM
  #32
hrcslam's Avatar
Those bastards! I guess I should've updated my profile huh? Not that my current times aren't still embarrassing.
Old Jun 11, 2015 | 12:01 PM
  #33
Man it jumps quite a bit. I am ok with the speedo getting behind. If it jumped like yours it would bother me some.
Old Aug 14, 2015 | 10:59 AM
  #34
ahritchie's Avatar
Congrats again, looks like they are stalking your car and and Suburban AGAIN on the front page of LS1tech with yet another article...... ..... how you get so much attention around here?!
https://ls1tech.com/articles/ride-on...2001-suburban/
I'm jelly...
Old Aug 14, 2015 | 01:12 PM
  #35
hrcslam's Avatar
I'm jelly...
This is weird. My cars are not front page worthy.
Old Jan 17, 2016 | 06:35 PM
  #36
hrcslam's Avatar
Update... finally.
So I decided that I would try and replace the VSS. It fixed the delayed issue. I also replaced the battery; I'm not sure what effect that had, but I can start my car more than once now......
I still need an under drive pulley kit to keep the Alternator running over 6K rpms though. But, no more jumping on my gauges between the Battery and VSS replacements. My Voltmeter still drops out over 6K though. Under drive pulley is needed. Hopefully I'll get it done in the next couple months.
Well, to be clear here, I only pulled through 2nd. Not sure if it will keep up through 3rd. I'll find out next time I hit up the track, which could be more than a year.
Nevermind. Spoke too soon. Its still doing it, but not as bad. I'll get that pulley done and report back then. Ugh
Old Jan 17, 2016 | 09:44 PM
  #37
SS RRR's Avatar
Village Troll
Update... finally.
You're welcome.
Old Jan 17, 2016 | 10:12 PM
  #38
hrcslam's Avatar
Originally Posted by SS RRR
You're welcome.
Read my whole post.....
Old Jan 18, 2016 | 01:49 PM
  #39
SS RRR's Avatar
Village Troll
You believe you're experiencing a voltage drop because the alt. is over spinning?
Old Jan 18, 2016 | 02:21 PM
  #40
hrcslam's Avatar
Yes. This didn't start happening until I replaced the alternator (I chucked the old one's pulley at high RPM). It cuts out every time I exceed about 6K. Changing the belt did nothing for this issue. I don't think I'm getting belt slip. So, I'm leaning towards an under drive pulley.
Also, I've broken the power steering bolts off at high RPM (I have stronger ones there now), and have damaged 2 A/C pulleys too (Sheared one between the clutch surface area and the belt area on the pulley, galled another one between the clutch and clutch surface of the pulley). Everything points to too much RPM.
