putting on rear end gears!?
Old May 23, 2004 | 01:54 PM
allenk's Avatar
Default putting on rear end gears!?
how is this done, i have no clue but am gonna pick up 4.10's once i know how.
Old May 23, 2004 | 02:45 PM
Vendetta's Avatar
I would have a shop do it.
Old May 23, 2004 | 10:48 PM
dhdenney's Avatar
A reputable shop for rear ends for all that goes. They have to be done right or you have a nightmare. The back lash and pinion depth has to be down to the .001" or you will go crazy. TRUST ME ON THAT ONE.
Old May 25, 2004 | 01:57 PM
Mikey 97Z M6's Avatar
It's a lot of work, but it's by no means "hard to do". If you can do a heads/cam swap, you can do a gear install.
You need a dial indicator that measures thousands of an inch w/ a magnetic base and some basic hand tools. Pneaumatic tools help but are not required.
Figure about a day, maybe two if it's your first time. My first time took about 6 hours start to finish but I had access to a lift and air tools. Do some more research, there are "how to" articles on the web that will help dramatically.
The way I look at it, if you're making 350+rwhp with the stock 10 bolt, you better learn to do your own gears, or upgrade the rearend lol....
Good luck,
Mike
Old May 25, 2004 | 02:54 PM
z28s's Avatar
The hardest part of the install is getting traction when your done...
