LT1 swap
For fuel system, see if you can find a fuel injected G-body pump and sending unit. I ran an external fuel pump myself. It is incredibly noisy. I had to modify the pickup too. I don't recommend it at all. You will also want to run new fuel lines. The stock return line isn't big enough to return all the fuel of the high flow pump.
If you can't find a fuel injected G-body pump and sending unit, I've seen people add an additional access hole to the tank and install an airtex or aeromotive pump. That way you can still have your stock fuel level sending unit.
I would recommend to replace the tank with a FI tank that has the fuel pump in tank. Tanks INC has all kinds of stuff.
http://www.tanksinc.com/
