idles too fast randomly
your IAC could also be dirty/bad...but the vdc thing is not right on the TPS
Pull TB and them pull IAC and use TB cleaner and spray IAC valve clean and also spray clean the TB and re-install. You will need a new TB gasket
also do not push or pull printle of IAC or it will break
if IAC is sticking and holding a higher idle than the TPS would show a "x%" higher vdc as a result which may explain the 1% vdc reading you are seeing
