Draining antifreeze with shop vac
Open the drain on the radiator and put the shop vac on blow where the thermostat is???
Open the radiator's drain ****. While the radiator is draining, assuming your shop vac is a wet/dry unit, empty and wash out the vac really well. Then remove the t'stat, and use the vac to suck out the coolant from the block. If you've washed out the vac really well, before you do this job, you should be able to re-use the coolant without any proble.
Drain radiator
Remove hoses
Remove two bottom w/p bolts that tap into water jackets
lower vehicle
let coolant drain
raise vehicle
boom
Either that or just take **** apart and use paper towels to mop up around the water jackets before placing new gaskets on block.
