Stop Replacing Opti's!!!!
However, I'd still go 24x today.
The LTCC, Delteq, and especially the 24x are superior set ups to the Optispark. But, replacing an Optispark with a "new" Optispark to throw parts at a problem because someone on a forum said it's the Optispark without any real troubleshooting? That's ridiculous.
Also, you guys apparently didn't read the thread as this is stated pretty clearly in my first few posts.
IMO, if you don't do enough research/diagnostics to make your OWN decision then I don't really care if you rebuild your damn motor just because a spark plug is fowled...I will just sit here and laugh.
AFAIK, I still have my OEM opti in my 95 with 66k mi and have not had any issues. It will stay in there and only be taken out to be inspected only if certain checks determine it is in fact the opti. At which point I will attempt to rebuild it and toss it back in.
I think it gets such a bad reputation is because it is not so easy to see/remove/install. If it was on the front of the motor unobstructed where you could do testing easier then people wouldn't get their panties in a wad about working on it.
I read your posts, and they are good. My comment was more for those who insinuate that the move to 24x is "unnecessary" because the opti can and does work. There are just other reasons for justification. I actually had the Dynaspark (gen 1) opti for awhile, and it performed flawlessly.
Trust that I'm no fan of throwing good money after bad in chasing down a problem by simply swapping parts without understanding the root cause of an issue. Been there, done that, so I appreciate the message.
The ICM does not control timing, the PCM changes when it tells the ICM to fire the coil. IF the ICM managed the timing there is no way you could replace it with a 4 pin HEI ICM and have the car run.
92-93 LT1s were batch fire not sequential.
I say it's their car if they have the money and want to. Let them, it does give the company's making/selling the product money/income.
Guess technology stopped after the optispark and went backwards, least thats how LT1 owners portray it.
Now I don't know what I am going to do with the LT1. It had oiling issues but it is in good shape other then bearings.
Yes it is in the 93, but I don't have recent pictures of anything other then the poor location of the o2 bung on the drivers side swap header.
