Lt1 odd behavior
Old Dec 1, 2014 | 02:53 PM
Camaro_ZL2's Avatar
Default Lt1 odd behavior
Alright guys i recently started having an issue with my car ill turn it on but it take about 3-5 times sometimes itll stall out after. other times itll stay on but sputter then it warms up and its fine for a while and then just die at a stop very randomly. another thing is does is when i floor the gas itll sputter, then go and then be fine then reach low rpms and sputter any ideas?
things ive done
Cleaned the MAF sensor,spark plugs
changed out the wires and the oil,fuel filter, and also the ICM
Fuel Pump was changed awhile back its walbro 255
If you have any ideas let me know
Old Dec 1, 2014 | 03:13 PM
BALLSS's Avatar
check fuel pressure at idle and also wot. a gauge with a hose on it so you can tape it to windshield
rule out FP issue...symptoms can also be Opti related
Old Dec 1, 2014 | 03:36 PM
D-Man304's Avatar
Sounds just like what was happening to mine except for the stuttering. I'd let it warm up and in a couple of minutes it would just die. Sometimes it wouldn't though and it ran perfect, even beating the crap out of it. It was the cheap opti I put in it. Next time it dies, check for signal from opti.
Old Dec 1, 2014 | 11:04 PM
Camaro_ZL2's Avatar
Checked the opti gonna check the fuel next
Old Dec 10, 2014 | 01:14 AM
Camaro_ZL2's Avatar
checked the fuel and the pressure is fine car still acts like its starving it self im trying to get a scanner to see whats going on and one know what a good scanner is since i have an obd1 with a obd2 connection?
Old Dec 10, 2014 | 02:24 AM
MedicinalCreamDogs's Avatar
i think you can just buy a cable to connect to a laptop. of course you'll have to download some free software to read the codes... that's what i did when i wanted to read my car's codes
Old Dec 10, 2014 | 11:28 AM
Jaxem's Avatar
Scan9495 is the best for this, and free! Gary also included instructions on how to make a cable for the obd 1.5 that our cars have for cheap. I did it and it works perfectly. If you go that route let me know, I have an extra universal obd plug you can have (otherwise you'll be waiting three weeks for one from China)
https://ls1tech.com/forums/pcm-diagn...-scan9495.html
