514HP/506TQ NA LTx. What will it do with boost?
To make sure everything was in proper order, I decided to have the engine broken in on an engine dyno before it goes back in the car. Karl swapped on a GM performance carb intake, 750cfm carb and basic distributor for the dyno session to keep things simple. I wasn't going for a number but obviously wanted to make sure the engine was healthy. Keep in mind the timing was around 34 deg and fueling was not ideal due to lack of jets and time we wanted to spend. Our goal was not for a perfect NA number but simply to break in the engine. Based on the results below, I'm very pleased but not quite sure what to expect when I throw 18-21 lbs of boost at it from a F1A Procharger. Any ideas?
General specs:
383 LTx - 9.5:1 Static Compression
Callies Dragonslayer crank, Callies rods
Diamond custom pistons (double diamond coated, gas ports, H13 pin)
LE Lunati custom blower cam (226/239 112 under 600 lift)
LE TFS 21 degree ported heads
Comp Ultra 1.6 RR, Crower link bar lifters
Results and video: 514HP/506TQ
This is just offered for perspective since we so rarely see engine dyno numbers.
IT will be fun to see your car on the on-ramps again.
Karl
Karl
Stacks!
You car will be a beast...hope you enjoy it!
If he can run 21# then maybe after the pressure drop, after every choke point, he could see 14-15# in the cylinder.
I would say 830 if pushing it hard, and keeping the air charge cool.
