LT4 intake manifold
Internally they are the late small trapezoidal port LT1 intake. Seems like most 95 and older stuff was more rectangular and larger.
The LT4 heads had big ports but the intake did not, this also means a little TIG work can make an LT1 intake a really good substitute, add material above the port so it can be port matched to a head with a bigger intake port.
Right, but most do not bother painting the bottom or inside the plenum.
Guys have run LT1 intakes unmodified on LT4 heads, the sealing margin is just narrow at top.
Mine is completely red, but yeah it would appear looking inside the plenum would be the best step to ensure it is genuine.
