Adding forced induction on higher millage vehicle
By the time you buy a supercharger kit, supporting mods, tranny, axle and freshen an engine to handle it not a full stroker build just a basic 355 and you will be in $8K in a blink. Far as strokers, it is a bandwagon often jumped on without understanding but if well built there is NOTHING wrong with them and the crank can even be liter than stock.
Watch out for ignorant folks offering you advise too.
And ya everyone has there own opinion hahaha and I don't mined hearing them at all!!
However, if the car is a toy and you have another way to get around if it breaks, then by all means, do it. You'll want to add a good set of headers and a couple other things, but it will live for a while on 7psi if you don't lean on it too hard. How the car is driven and cared for has a lot to do with it. If you put a blower on it and beat the hell out of it on a regular basis or in hot weather, then it will likely pop pretty quickly. If you exercise some restraint and only run the car hard occasionally and when the weather is not really hot, it will likely last a while.
When it does eventually break something rebuild the shortblock with forged pistons and rods, upgrade the heads and camshaft, add more boost and make big power.
If you decide to go the N/A route, 400+rwhp is easily attainable on the stock shortblock with a good set of ported heads and matching camshaft. I wouldn't worry about the mileage too much, if the motor still holds good oil pressure and a leakdown test shows good results you will be fine.
You'll due yourself a favor if you call Advanced Induction or Lloyd Elliot. Let them spec you cam and port your stock heads. You'll have around 450 FWhp or 400 RWhp.
Seriously, good plan. Carry through with it.
My last post to the troll.
Youre 18 and you need some guidance. Good God, you've only really been alive for what, 2 years or so? Ive probably driven farther backwards than you have forwards! Take the hand when its extended to you. You have an old used up Camaro that you want to add forced induction to, and Edelbrock heads?? weve all been there and had the same pipe dream youre having now. Take it from us, theres a correct and incorrect way to start a build on an engine.
First, its your daily driver, so just use it as transportation like it was meant. Ripping into an engine requires time down...Can you afford that? Its a high mile car that probably needs everything looked at, from suspension, tires and brakes to engine, trans and rear end. Don't just take your tax return and dump it into a set of heads that wont do anything for your car anyway.
Start with safety items like, suspension parts that we know are worn out. Brake linings, hoses and rotors... Providing you have the facility, (garage) and the correct tools, much of this kind of work can be done at home. Special tools can always be rented.
You mentioned horse power levels...how do you know what they actually are now? Have you paid to have it dyno tuned, or are you guessing? Pic of dyno sheet? You cant just take the vendors advertised power numbers and add them all together and majically have 400 horsepower.... it doesn't work like that. It would be surprising if you have 250 actual rwhp...
Post up a few pictures of what youre working on so we can help you evaluate the project overall. Engine, suspension and maybe some under carriage shots would be great.
We can go from there.
Hell much of the documentation suggests their intakes are a step down in power.
If you really are an ignorant 18yo, then stick to some boltons(exhaust, CAI) for now and spend a couple years getting a clue.
If you are a troll then I suggest buying a tornado, every ignition mod you can find, maybe some 1 7/8" to 2" stepped headers, an adjustable FPR, the biggest Aeromotive pump you can find at least 80lbs injectors, the edelcrap LT4 kit, and a JET piggyback tuner, and don't forget the electric fuel pressure gauge and narrowband AFR gauge on the pillar.
