383 LT4 dyno tune results
FWIW, my friends 383/GM846 built by a local guy who gets more hp out of LT1's than most, in an M6 Vette, put down almost identical SAE hp/tq numbers as your 846 setup, so I'd consider that number solid. His heads are home-ported LT1's copied from Lingenfelter's port job.
From your original post, I just assumed those LT4 heads were a top-of-the-heap port job, in which case the numbers are attainable with the 847 cam. My 350 with a 228 duration cam is within a couple hp of you when you factor in the A4/converter losses.
0.4 more compression
ported chambers, heart shape now and unshrouded valves.
stock gear wp vs electric wp and cloyes dr chain now.
1 5/8 headers vs 1 3/4 headers now
42lbs steel fw vs 13lbs alum now
intake opened up to 58mm to match 58mm tb. same tb as before.
quench before .045 now .042
red top 30lbs inj. before bosch lll 40lbs from fic
stock opti vs deltec ign. now
think that's it
I'm believing the numbers again
