Header Install in NJ, PA
Old Mar 21, 2015 | 06:25 AM
Dave2500's Avatar
Default Header Install in NJ, PA
Hello,
Im looking to get a price on installing headers on a LT1 car,
right now i dont have the time too do it myself
Every shop that i talked to said they only work on ls1's ,
so does anyone know who will install lt1 headers and a ball park idea on pric
thanks
dave
Old Mar 21, 2015 | 06:49 AM
99Brd's Avatar
Default Header install
I'm in the MD area, but I'm pretty sure that Rapid Motorsports in PA could install headers on an LT1. I also believe they have one of the best tuners in the area. Hope this helps...
Old Mar 21, 2015 | 07:12 AM
Shownomercy's Avatar
Man-Crush Warning
Whats your budget?
Old Mar 21, 2015 | 07:13 AM
Dave2500's Avatar
Thank you i will call them, thanks again
dave
Old Mar 21, 2015 | 07:14 AM
Dave2500's Avatar
Whats your budget?
Tell me if im far off but i already have the headers, gaskets and bolts so i was hopping labor to be around 500 is that too far off?
THanks Dave
Old Mar 21, 2015 | 07:18 AM
Man-Crush Warning
I would also anticipate doing motor mounts, spark plugs, and wires.
Edit: And 02 sensor extensions
Old Mar 21, 2015 | 07:23 AM
Dave2500's Avatar
So do you think 500 for labor is close to the going rate or is it to little?
also do you have a cat back you would suggest for headers into a 3" ORY (no cats)
Old Mar 21, 2015 | 07:25 AM
Man-Crush Warning
$500 isn't bad, but its not a job I would wanna do on a flat rate.
Exhaust bolts could snap etc and then a simple couple hour job is magnified into an all nighter.
Magnaflow, Corsa, B&B, Hooker would get my vote.
Old Mar 21, 2015 | 07:30 AM
Dave2500's Avatar
ill be 100% honest,
you can look at my old posts, on my old car i did the headers and it was a nightmare. most of the bolts had little tabs on them from the old exhaust heat shield that had to be ground off, i just dont want to get involved again
i love lt1's just dont like working on exhaust after the last one,
and the weird (or smart idk) thing is many shops that i called will not work on a lt1
Thank you for all the Info
Dave
Old Mar 21, 2015 | 09:30 AM
PA94Z's Avatar
Those shops are a bunch of idiots if they cant put a set of headers on. It's not that hard for christ sake. You should just get yourself a engine hoist, jack stands, and do it yourself. Save some money too. You can unbolt the motor mounts and hoist the motor, they slip in from the bottom easy.
Stubborn exhaust bolts just need a little heat and out they come. They won't snap if YOU don't snap them
Old Mar 21, 2015 | 09:23 PM
Dave M's Avatar
I've never used them so I can't endorse, but check out DGR Performance
http://www.dgrperformance.com/services/
Old Mar 22, 2015 | 11:31 AM
NewOrleansLT1's Avatar
For the shops to say they won't put headers on an LT1 because it's not an LS1 is BS.. They're still F-Bodies at the end of the day.. I'm pretty sure the concept of installing header on either car is very similar..
Old Mar 23, 2015 | 09:04 PM
MuhThugga's Avatar
You can always bring it around my way.
Old Mar 31, 2015 | 03:41 PM
ThoR294's Avatar
Where are you located in NJ?
Old Apr 2, 2015 | 11:38 AM
MonmouthCtyLS7's Avatar
Pretty sure tune time in Lakewood works on LT1's but I guarantee he's going to charge you more then $500, his work isn't cheap.. A lot of shops in the late 90's didn't want to touch a LT1 header install, I see something's never change. The shop that did mine did nothing but complain through the whole process
Old Apr 2, 2015 | 02:23 PM
ThoR294's Avatar
My uncle owns a garage in Lebanon and he will do it. He has been in business for over 40 years
Old Apr 2, 2015 | 04:35 PM
OwieVT's Avatar
These broken bolts stories make the job sound worse, I guess I was lucky. I put headers on my 1994 Z28 a couple years ago. The car 180k miles and all of the bolts easily backed out without breaking any of them.
Old Apr 2, 2015 | 08:11 PM
ThoR294's Avatar
my bolts broke flush with the flange, so when i got the headers off I was able to take them off with those easy out sockets (they tighten while you loosen)
Old Apr 3, 2015 | 11:07 AM
sweetbmxrider's Avatar
If a shop is scared of putting headers in, what the **** would they be ok with? Drop in filters?
Old Apr 3, 2015 | 05:56 PM
Dirty_Bird's Avatar
even those are risky still. metal tabs may break off the air box
