Will the wrong flexplate cause damage?
If you say the machine shop cannot find record, does that mean they are looking at a build sheet stating they have no record or does that mean they have no record of the block being built?
you will know IMMEDIATELY when you start the engine with a weighted flexplate on a "internal" balanced motor. It will vibrate like a dog shiating razor blades. You don't want to run the engine long this way.
If the shop can't find it's records as to "how" they balanced the rotating assembly...you have a 50-50 odds of the flexplate you have working
One + is the guy you got it from gave you the flexplate & damper (ATI is a very good one) and those parts are not cheap so there is a likely chance the flexplate was balanced with rotating assembly
If you can't get the confirmed records from machine shop you either roll the dice and try what you have or tear the short block apart and have the balance confirmed by machine shop
as SSR notes, you will have to have any replacement flexplate (should you ever need one) balanced to = whatever the Scat weighted one is
Would the flexplate be perfectly zero balanced then, possibly but ideally you want the machine shop to neutral balance one...even if it says it is zero balance, always worth checking before install IMHO
