what oil pump do i have?
Old Jun 2, 2004 | 12:03 AM
TSAEB's Avatar
Default what oil pump do i have?
Ok a friend (mechanic) told me that i was getting bad oil pressure...took the valve covers off and said the oil took to long to shoot up...he said tha my car drops oil pressure to much and to fast...my oil pressure gauge show it goes to about 61 and no more and down to about even 20....he said that it should go up to about 80 and stay higher that 20...so he sugguested i buy and new oil pump and if it didnt fix the problem to look and the lifters...i dont he is trying to rip me off..cus the work will be done by a cousing anyway...so is what my mechanic saying true...and my last question i checked to buy a stock oil pump and i was told to check the size of the oil pump....supposedly there are two types of sizes...how can i check to see what exact oil pump do i need...or should i just take it off and go to a auto store and compare the both.
Old Jun 2, 2004 | 12:04 AM
TSAEB's Avatar
oh...is there anything i should know about changing the oil pump...what to do/to remember/to know...any tips would help thanks
Old Jun 2, 2004 | 12:35 AM
brandboZ28's Avatar
My oil pressure was running a little low and it ended up being that the pickup tube had fallen out of the pump and was just alying in the bottom of the pan. Tell me this, idoesn your oil pressure drop all of the way down when you come to a quick stop? Thats a pretty good sign that this has happened. Another way to tell is to hit the bottom of the oil pan with a rubber mallet and if you hear something rattling around in there, the pickup tube has probably fallen out.
