Car shutting down at random intervals
Old May 18, 2015 | 08:14 PM
memphisown80's Avatar
Default Car shutting down at random intervals
I don't think it is fuel related as their is no sputter before it shuts off. Car shuts off at idle, while accelerating, and while maintaining speed. Sometimes it will start right back up. OTher times it acts as if the fuel pump is clogged and have to wait for pressure to drop to start again.
Stumped right now. Spent the weekend putting on a new optispark. Changed the thermostat and water pump while I was at it. The wiring harness was skinned a little but, we wrapped it pretty good while waiting on a new one to come in.
Aside from the wiring harness being the issue. There are 2 other areas of concern for me with this problem.
1. The oil pressure warning is on while at idle. But, after it warms up, maintains the pressure at halfway when cruising. Have checked the oil and oil pressure and everything there is fine. PRetty sure it is the oil pressure signal unit being faulty. But, will that cause the car to shut off at times?
2. There is a ACCEL300+ racing ignition installed on the car. But, it isn't hooked up. From what I read on those, it prevents failures due to wiring issues.
Could that cause my issue?
When the car is actually running, it is a beast of a vehicle. Just have this issue with it cutting off at times.
Old May 19, 2015 | 06:28 AM
bufmatmuslepants's Avatar
The oil pressure thing is normal, GM says you only need 10psi per 1000 rpm, and hovering just at the red while at warm idle is normal. Many of our cars do this including mine.
The shutting down could be a loose battery terminal, had that happen to me.
Old May 19, 2015 | 08:21 AM
I prayed that was the issue before I put on a new water pump and optispark.
Old May 19, 2015 | 09:51 AM
SS RRR's Avatar
Village Troll
Check the power dist. block on the pass. inner fender to make sure connections are tight as well.
Old May 19, 2015 | 09:58 AM
Thanks. That is definitely something new that I know hasn't been checked
Old May 19, 2015 | 10:02 AM
ahritchie's Avatar
Mine did this when the ICM was going haywire.
Old May 19, 2015 | 10:26 AM
My father in law replaced that as well. Now, he got it from pick and pull from a wrecked car. So, it could be the issue still.
Old May 19, 2015 | 12:40 PM
SS RRR's Avatar
Village Troll
Nevermind. When cutting out, power to the guage cluster will also cut out. As mentioned it sounds a lot like a coil or ICM issue. You can do some testing and use this for reference:
http://shbox.com/1/coil_testing.jpg
