MAF vs SD on 73 Camaro Swap
Reading through the forums here and on NastyZ28.com I can't get a good enough feel on my need for this sensor. I have not had the harness adjusted yet and have not had the ECM programed yet either.
So does the cost of the MAF Sensor justify the need? Or wilting it out be the best course?
But, I will say both should be done regardless (if you do go MAF mode that is). If the MAF ever fails and your SD isn't tuned for your build it'll rear is ugly head in a very unstable way. I found this out the hard way, which is why I did an SD tune.
I was just wondering if I really needed to go out and buy this sensor to make it work properly or if it was one that could be easily be left out without giving me (a novice) no issues later on.
So from what you guys are saying it sounds as if I should go ahead and get this part. Where Is the best place to source it? Used/ New?
It will run without it...provided the other critical sensors for SD are present and working right.
You can pick up a Delphi unit at Rockauto.com for just under $100. They are under the "Emissions" category of all places. I was looking under Air/Fuel and could not find it.
ACDelco offers a Reman unit for $140. With that you would get the metal housing(which is how they came stock). The Delphi appears to be all plastic.
http://www.carid.com/1996-chevy-cama...FZJffgod0wcAPA
I have no experience with that brand so I can't say if they are good or not.
