track times
Old Aug 6, 2015 | 12:30 PM
Mystery Bird's Avatar
Originally Posted by hagff95
The first pass didn't spin at all just pressed the gas and went and the second I raised it to about 1000rpm and spun a tade and on the second pass my car did hit Rev limiter from 2 to 3 and I think that Is because the Trans gets a little to hot. So the second pass probably could of been a little quicker I have 3.42 to put in the car but I feel like my 2.73s should be able to pull a better time than that and yes I did do a small burn out to get the dust off and I did avoid the water and this is with an a4
If you have 3.42's to put it just hanging around then do it. You won't believe the difference it will make.
Old Aug 8, 2015 | 10:20 AM
Birdracing's Avatar
Go 373's if i were you than get a tune you will see a big difference in the car than. The DA is not helping you at all funny how that can affect a car but it does big time.
