Need some advice please
Old Aug 21, 2015 | 06:52 PM
Stephen Manchester's Avatar
Default Need some advice please
Well guys, i think i may have found my problem. A little history first. My 95 TA blew the factory LT1 up this last winter. After looking around i found a good deal on a low mile, 375 HP LT1/LT4 out of a 93 Corvette. i paid to have the motors swapped out due to not having a garage. Long story short, after a long time of my mechanic being ill and no work getting done on my car i went a picked it up yo finish myself. i got everything hooked and bolted back together and ready to test fire. after cranking all i would get was maybe a hit and even a pop back through the intake. i inspected all wires, plugs and firing order. i also tested the fuel pressure and checked all vacuum lines. after determining it was a problem in the ignition i removed the opti. wow, this is what i found. the opti looked as if it had been broken in several pieces before and someone had made a lame attempt at gluing it back together. after getting it apart this is what i found....give me your input as well as what my best option for replacement would be.
Attached Thumbnails Need some advice please-10346273_1490284644620339_1433732150096746287_n.jpg   Need some advice please-11866495_1490284634620340_1329218654302479463_n.jpg
Old Aug 21, 2015 | 07:18 PM
myltwon's Avatar
AC Delco opti, Delphi, or verified (locktited rotor screws, etc.) MSD
Old Aug 21, 2015 | 07:22 PM
madmike9396's Avatar
2nd ac delco
Old Aug 21, 2015 | 07:54 PM
seymourbuttz's Avatar
Thoroughly inspect rest of motor. Looks like that sucker may have been in water.
Old Aug 21, 2015 | 08:46 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
It's not uncommon for the water pump to leak, or seep, onto the opti. My factory original opti looked a lot like that, and to be honest it probably looked a lot worse, when I removed it after 100+k miles. In my opinion, what you are seeing is very common. If you get a new opti, get a Delphi, which may be new, or an AC Delco, which will more than likely be a reman at this point.
Being broken is up like that is probably not common, but the rust is very common.
