95 vette balancer line up
Old Aug 23, 2015 | 04:57 PM
Vettelt1's Avatar
Default 95 vette balancer line up
Pulled balancer off away from Hub on crankshaft to replace optispark. Has three bolts that holds it on . My question, is there a certain way it aligns with Anything on the hub? Ready to put back on, just want to make sure I get it on correctly before bolting up water pump
Old Aug 23, 2015 | 07:44 PM
Jaxem's Avatar
It's non symmetrical, so it only goes back on one way, hard to tell just looking at it, but you'll see what I mean when you go to put it back on
Old Aug 23, 2015 | 07:50 PM
shbox's Avatar
Yeah, can only go on one way. Arrow on the pulley matches to a line cast on the hub.
Old Aug 23, 2015 | 10:51 PM
Vettelt1's Avatar
Thanks guys, got water pump back on, seems to run good. I probably need to bleed the air out some more. But the hard part is done. Thanks again!
