700r4 lock up problem
Old Aug 27, 2015 | 11:18 AM
timopajala's Avatar
Default 700r4 lock up problem
Hi. I´m strugling with my newly reduild trans. It locks up only when cold about few minutes etc and after that nothing. I have switch for it that gives the pcm 12v on and off. Where should i look for the problem?
Old Aug 29, 2015 | 12:30 PM
kinematics's Avatar
700R4's require 12 volts to enable the lockup. This means that somehow you are supplying 12 volts to the transmission when the engine is cold. I think that you should try to use a digital multi-meter (DMM) like a Fluke DMM and measure the voltage on the lockup wire. I don't know exactly what's causing the problem, but I think looking at the voltage on the lockup line is the first place.
Old Sep 5, 2015 | 02:08 AM
timopajala's Avatar
thanks for the info! I will look for the voltage on the lock up wire.
