Camonlyjabroni, Ahritchie,- I had bald tires at the strip!! I have B F Goodrich comp 2's on the rear now. They def hook better and should drop 1-2 tenths off my 60 when I run it again next april.Hellteeone- My goal with H/C is anywhere in the 12's @ 110+. I dont care about the 400rw bragging rights or 11 sec cars that idle like ****. I agree ls1' s are no joke with bolt ons. I want to get away with a solomon mail order tune. Would that work? I might go bigger with the cam but not at the cost of driveability. Would a cam with 230 duration idle okay? What LE cam would you rec for a 12 sec Daily Driver? 224/230 @ 112 lsa? I would think that cam would get at least 370rw if tuned properly.
It all depends on what you consider "idling like ****" I guess. 230 degrees of intake duration is not what I would do with most H/C setups. Typically, a cam with 230 or more degrees of intake duration is going to want 11.5 compression or the midrange could be soft. If you have a modest bump in compression through use of a thinner gasket, I'd go upper 220s at most. Something like AI's 226/234 will drive well if you have a good tune and make good power too. My car with the 228/234 on a 108lsa drives well, but there is some minor surge down low. Some of that is due to the fact that I'm running stock 3.42 gears though.
224/230 112 lsa is not a LE grind to my knowledge, that's a popular Comp XE grind that has been around for years. Really popular with folks who run a "cam only" setup with stock untouched heads.
My previous post was more about springing for the better heads than with getting a really big cam. Though I would consider something in the mid 220s on the intake side and with a healthy amount of lift to take advantage of a good set of heads.
Solomon does good work and tuned my car. He is now going to tune it on E85. Ordered the Cable Loan Power Tune from him Wednesday night. My car is a 230/236 .510 .520 w/1.5 rockers and it has 1.7's on it now. It idles great. Just smells strong of fuel. Nothing you can really do with a bigger cam and no CATS.
I'm going with the LE 215/227 .546/.565 111lsa cam and le1heads. Should make for a good daily driver. Going from 255-260rw too 350-370rw should feel nice driving to work. Thanks for all the advice. I will need lots of help with this winter build from this forum. Is there anything in advance I can start buying right now before I tear into the engine this december? Lloyd rec lunati lifters if my stockers are worn. Any good self aligning rr's or pushrod recommendations? Thanks again Lt1 gods!
