Lt1 steam pipe
Old Sep 20, 2015 | 04:04 PM
Alex-chevy's Avatar
Default Lt1 steam pipe
Hey everyone,
I am finishing my LT1 383 installation. I am a little confused with the "steam pipe". I have correctly installed the pipe in the back of my heads. The end of the pipe that runs up to the throttle body has me uncertain. I have read that I can bypass the throttle body connection at this point, and in fact run a rubber hose from the end of the steam pipe to the radiator nozzle second from the top on passanger side of radiator. I am not sure if this is correct though, I am worried over flow antifreeze may seep from the radiator into my steam pipe causing over heating issues. Does anyone run this setup or understand it?
Thank you!
Old Sep 20, 2015 | 04:08 PM
Alex-chevy's Avatar
These photos show what I am referring to with the steam pipe to radiator connection.
Another picture of steam pipe to radiator connection.
Old Sep 20, 2015 | 04:09 PM
Alex-chevy's Avatar
Thank you!!!!
Old Sep 20, 2015 | 04:21 PM
hrcslam's Avatar
This is exactly right. The steam pipe is an important part of the cooling system. It will not take any "overflow" coolant because it is part of the pressurized coolant system.
Old Sep 20, 2015 | 04:24 PM
hrcslam's Avatar
Also, you want to hook up the top line (if you didn't already) too. That's for the overflow reservoir, without it your radiator can't pull in coolant after it cools down and contracts. It'll pull air in instead and that will lead to overheating.
Old Sep 20, 2015 | 04:25 PM
Alex-chevy's Avatar
Thank you very much hrcslam!
Old Sep 20, 2015 | 07:36 PM
shbox's Avatar
It's commonly called a "steam" pipe, but it carries coolant just like the other hoses. Only it also picks up any pockets of air (steam) that can be formed by coolant in the LT1 reverse flow system going from the radiator to the heads first (unlike the previous SBC flow).
Old Sep 20, 2015 | 08:02 PM
Alex-chevy's Avatar
Nice....yeah I am hoping the small diameter of that pipe stays open for many miles....
Old Sep 20, 2015 | 09:26 PM
96capricemgr's Avatar
Seriously, you don't understand the TB bypass yet have a 383 going in. This should be interesting.
Old Mar 2, 2018 | 05:53 PM
Alex-chevy's Avatar
What do you think about the an and npt fittings modification for the steam pipe passage? I can't decide if it's something I should do.
Thank you!
Old Mar 2, 2018 | 05:54 PM
Alex-chevy's Avatar
Thank you!
Old Mar 3, 2018 | 05:43 AM
atlantadan's Avatar
If you're not having issues with the metal steam pipe, I'd use the money elsewhere. It does look cool, though. I'll give you that. Make sure you use the correct steam pipe seals - NOT oil plug seals
