LT1 performance advice
Old Sep 25, 2015 | 07:16 AM
CamOnlyJabroni's Avatar
Originally Posted by Vicious95Z28
My cam only car, mods in my sig. On Mickey Thompson dr's from a roll I busted every tooth off of the ring gear but 4. This wasn't revving and dumping the clutch it was a simple turn off of one street onto another and when the car straightened out in the road I nailed it. Bang, clang, crash....Ugh, tow home.
When mine blew I did the exact same thing. Turned a corner as my car straightened out quickly gave it half throttle and boom. Only a mile from my house and had to get a tow lol. 383 just pooped the ten bolt right out.
Old Sep 25, 2015 | 04:09 PM
HellTeeOne's Avatar
More than likely you didn't break all of those teeth off at once. Once you break a couple, the rest come pretty quickly with a sudden application of torque. When I took my 10-bolt apart, it had 2 broken ring gear teeth and one pinion tooth broken. I didn't even know it was broken at the time. Guy who did the work said I was likely one throttle stomping away from catastrophic failure.
