weird overheating issue?
My car will slowly overheat if i go over 60 mph for an extended period of time, not 59 mph, but exactly 60. weird right?? i could drive on the interstate going 75 mph, and like five min. later it will start to slowly rise. i can slow down to sixty or below and it will cool back down slowly. i can drive around town for hours and it wont overheat. but interstate or extended hwy is a different story. thanks guys.
Chaz
The cooling fans should turn off at 36mph (unless the car is way overheating) according the the stock tune. At 36 MPH the air flow through the radiator matches what the fans can pull through it anyway. Above 36mph the fans being on can reduce air flow (albeit not enough to cause cooling issues, but they are not needed and will only increase engine load via the alternator and reduce fuel economy).
OP, next time you are at say 55MPH select a lower gear and get the RPMS up just a tad (like the same rpm you would be in at 75 or so in high gear). If the condition repeats, look into a coolant flow problem. If not look into an airflow problem.
Is the air dam installed and not damaged? Are the ducts and plastics parts in front of the radiator secured so the wind doesn't blow them on to the condensor?
