Lt4 hot cam kit on 95 firehawk
If you want you can run the stock stamped rockers with the hotcam and still get a good power boost while you decide on a 1.6 rocker. FWIW the Comp roller tip rockers you linked are the best ball pivot rockers available. They are designed to have a accurate ratio unlike the stock stamped rockers. As long as you break them in carefully and don't exceed 350 lbs open spring pressure the pivot ***** won't gall.
If you think you might step up the HP and max rpm at some later date it makes sense to buy good NSA roller rockers, 7/16 studs and guide plates now so you don't buy stuff twice.
