Gears!
Old Nov 19, 2015 | 07:23 AM
mr_adaya's Avatar
Default Gears!
3.73s or 4.10s?? Best gear ratio for quick acceleration on the streets plus good/okay for daily's
Old Nov 19, 2015 | 07:50 AM
superspirit's Avatar
Need more info, bolt ons? trans? lots of things to consider.
Old Nov 19, 2015 | 08:38 AM
Jaxem's Avatar
Can't speak for 3.73's but I went from the stock 3.42 to 4.10's and love it, it does make 1st and 2nd feel pretty dang short when driving in lower rpms, but there's enough gears (assuming 6 speed) that you won't be revving too high or anything. Made about as much SOTP difference as long tube headers (quite a bit)
Old Nov 19, 2015 | 09:13 AM
shbox's Avatar
3.73s for auto
4.10s for manual
Old Nov 19, 2015 | 12:28 PM
Fast350Z's Avatar
3.73s for the street or daily driver.
Old Nov 19, 2015 | 03:28 PM
Shownomercy's Avatar
Man-Crush Warning
You need what rpm you make max power at, and what size final gearing is trans wise, along with tire height. Match that in calculators with what you expect to trap based off your HP/Tq and voila, you have found your gearing.
Old Nov 19, 2015 | 05:17 PM
VoyagerCamaro's Avatar
Or be typical LT1 owner and run 4.10s in an auto and complain first gear is worthless! #LT1logic
EDIT: OP; Listen to show no mercy if your concerned with 1/4 mile ET's, or just looking for a fun street car, listen to shbox. There's some in between gears like 3.90s or 3.92s, but I'd stick with the traditional 3.73 or 4.10s.
Old Nov 23, 2015 | 01:44 PM
MonmouthCtyLS7's Avatar
3.73s for auto and 4.10s for manual is he general consensus but I know a few auto guys that are happy w/ 410's. Guess it all depends on what you plan on doing w/ the car, fuel concerns, etc.
Old Nov 24, 2015 | 12:19 PM
Mystery Bird's Avatar
3.90's here.
Old Nov 24, 2015 | 01:52 PM
Originally Posted by Mystery Bird
3.90's here.
I've heard that in the 7.5 the pinion gets very small w/ anything numerically higher then 373's in a stock A4.
Old Nov 24, 2015 | 03:09 PM
You're absolutely correct. I failed to realize or mention that I run a 12 bolt.
