help with low iac numbers
Old Dec 13, 2015 | 12:03 PM
hrcslam's Avatar
You attached the .exe of Datamaster. We need the Run file ( .uni file ), not the program ( .exe ). This is a puzzler for sure.
Old Dec 13, 2015 | 01:04 PM
Naild's Avatar
Try this again.
File Type: zip
Old Dec 13, 2015 | 01:15 PM
Naild's Avatar
This one commands data master to open the file.
File Type: zip
Old Dec 13, 2015 | 04:46 PM
hrcslam's Avatar
Originally Posted by Naild
Try this again.
In this log, were you idling in gear? If so, everything looks good! The IAC counts are a little low, but the AFGS looks right on par for your idle RPM. I'd say you probably have the TB blades open a little bit or maybe someone drilled holes in them before you bought it. But, it's nothing I would worry about. It would only need to move UP from where you're at. Turn on the A/C (if you have it) and you'll likely see the idle remain, but the IAC counts go up.
That and you're a little rich, but nothing that the BLM can't (and did) trim out. You could easily adjust that out if you wanted too though. Nothing worth fussing over.
Is it still burning your eyes rich? If so then you'd want to address that with O2 target (swing voltage IIRC), but you'll want to confirm that the O2's are targeting the wrong AFR before you adjust that with a Wideband. But, if you are not running a cat(s), it may seem rich even though it is not.
Old Dec 13, 2015 | 09:40 PM
steveo_'s Avatar
the most you'll get out of altering the swing point on a narrowband is like going from 14.7 average to 14.5; it wont help fix 'burning your eyes' rich.
usually burning your eyes rich is actually lean misfire due to the ecm trimming out too much fuel with corrupted o2 readings at low airflows, high cam overlap, and reversion making the maf readings way off...
adjusting filtering/delay timing/strength at low airflow can help a bit
Old Dec 14, 2015 | 12:15 AM
Naild's Avatar
The engine has no ac no cats and a manual transmission. The butterflies are closed tight, not sure about the holes but dont remember any??? Thanks again for the help, dont think wide band 02's are in my future, heaver axles and lockers well thats a different story. I might work with the tuner and ask about the target of the 02's.
Thanks for the help I got the miss fixed and its getting decent mileage again.
Stevo, the engine is stock... no high overlap. Wide band 02's have been in the back of my mind for years maybe after im done spending the next million on the build.
Old Dec 17, 2015 | 09:57 PM
Naild's Avatar
So I have to say the issue was a exhaust leak that you could not hear by ear, or it wasnt very loud. I pulled the passenger side header to find exhaust tracers out the gasket. Picked up some new ones and the split trim problem went away. The low IAC numbers didnt change although it runs better its still a little rich. Will work on that next.
Thanks for the help everyone.
