lt1 manifold interchangeability
But the 94 auto's had same manifolds as the 6 speed.
I don't know about the 93's.
The 95+ with A4 that are CA emission have slightly different manifolds. The thread at the air pump check valve pipe into manifold is a different size, and the manifold flange is different.
Just like to point out all the 93-97 exhaust manifolds are interchangeable but, the correct manifold that came with the car depends on what manifold you are looking at. There are more than one type of manifold so I would be specific when you tell the seller what it came out of.
If your 95 is Auto then they would be same threw these years 95-97 auto exhaust manifolds
If your 95 is 6 speed then they would be same threw these years 94-97 T56 exhaust manifolds.
