LT1 Fuel Return
Old Jan 7, 2016 | 11:44 AM
ART T's Avatar
Default LT1 Fuel Return
Could I use an LS1 Corvette filter/pressure regulator and eliminate the return line on a 1996 LT1?
Old Jan 7, 2016 | 11:46 AM
Shownomercy's Avatar
Man-Crush Warning
If you got it tuned for that rail pressure, I don't see why not. Tune may also need changing from the 1:1 ratio FP to a set FP.
Old Jun 21, 2016 | 05:18 PM
ART T's Avatar
Sorry for the delay. Could you explain this a little farther.
Old Jun 22, 2016 | 06:27 AM
Man-Crush Warning
The LS1 vette setup is set for 55psi, and it will not rise/fall with engine vac. Whereas your current LT1 PCM operates off of a fuel reg set to base pressure of ~40psi that will change pressure based on engine vac.
