Fuel Line Schrader Valve Problem
Old Feb 12, 2016 | 10:25 AM
Snorkelface's Avatar
Question Fuel Line Schrader Valve Problem
I need to replace my fuel filter. After the turbo system was put in, where the Schrader valve would be you can see there's now a connection. How do I relieve the pressure now with this setup?
Thank you for any info!
Old Feb 12, 2016 | 10:32 AM
Shownomercy's Avatar
Man-Crush Warning
You don't?
Just let the car sit for a while, place bucket under fuel filter, unhook, and swap.
Old Feb 12, 2016 | 10:43 AM
Oh...I see. I just tend to have bad luck when I skip any steps. Haha. Okay, she hasn't been run for a few days so I'll give it a try...and not smoke while under the car. Haha
Thanks.
You don't?
Old Feb 12, 2016 | 10:58 AM
sweetbmxrider's Avatar
If the system still has pressure, when you disconnect either line from the filter, pressure will release along with gas. Its not very exciting.
Old Feb 12, 2016 | 02:27 PM
No bueno. :/ For reference though, I have a fuel pressure gauge in the cabin which this is the sender for. Not sure if that helps clarifying.
Old Feb 12, 2016 | 11:09 PM
steveo_'s Avatar
another easy way to bleed off your rail pressure is simply pull the two injector fuses and crank the car for a few seconds. the injectors will blow the pressure off quickly. or apply 9v or so to an injector for a sec (not 12v or you might blow an injector coil)
Old Feb 13, 2016 | 05:25 PM
That's interesting, I would have figured that would build the pressure in the rail since the fuel would have no where to go. That would be a great solution!
