bogs when accelerating and smells of gas after warm up
Old Mar 2, 2016 | 02:20 AM
CamaroWhoopAss's Avatar
Originally Posted by fbody_brian
Maybe I'm just lucky. I disassembled mine and cleaned everything good. I bought a cheap chinese opti and transferred my original mitsu sensor to the new opti, as mine's bearings were shot. I did this almost 5 years ago. So my "optical eye" is still going strong after 190k in an unvented oti. I just replace the cap and rotor and inspect every few years, but like I said, maybe I'm just lucky.
Now that I've said that, I expect my sensor to die sortly
Hey that's a pretty good idea to buy a cheapo one and transfer the eye.
Old Mar 2, 2016 | 02:59 AM
hrcslam's Avatar
If you buy a cheap one, make sure you compare the drive side to the rotor side between your old one and the new one. The cheap ones have been known to be pressed together wrong.
Old Mar 2, 2016 | 11:04 PM
Zachary David Bell's Avatar
so right after i got the codes read it started driving just fine haha i havent done a thing to it. if it starts acting up again ill go from there. either way im gonna pull plugs just to check but life once again is hectic and not allowing me time to do so
Old Mar 3, 2016 | 02:31 AM
You know for it to randomly be fine like that kinda points at opti like I was saying earlier. Maybe it finally dried out or something. I wasn't the only one who suggested opti either. And the weather patterns right now of cold-warm-cold-warm would create a moist enviroment under the hood...
Old Mar 7, 2016 | 08:56 AM
Everything was fine for a few days then started acting up again. I replaced the o2 sensors since I had them laying sround and its been good since. If it again starts acting up ill start going through everything again haha it all checked out though
Old Mar 7, 2016 | 02:25 PM
Cool, glad it's running good.
