About to get first round of mods for my 1995 C4
Old Mar 6, 2016 | 06:12 PM
  #41
trilkb's Avatar
Well it sounds like I have everything picked out but the springs, it seems I may have luck with afr guideplates clearing with no modifications as well.
So the 98213's...anyone see a problem running them?
http://www.competitionproducts.com/mobile/Howards-Cams-Performance-Valve-Springs-1265-OD-120-1800-350-1200/productinfo/98213/#.VtzHCvROlAg
120 seat, 350 open
Old Mar 7, 2016 | 01:47 PM
  #42
lt1-xjs's Avatar
I would go with the 98215 spring, a much better spring for a little extra money. The stock 1.780" install will give you 135# on the seat.
Old Mar 7, 2016 | 03:47 PM
  #43
trilkb's Avatar
The 98215s definitely seemed like the better spring. Just wasn't sure if they were too strong. I'll give them a go.
Old Mar 15, 2016 | 04:50 PM
  #44
trilkb's Avatar
well I just ordered all my crap
OBX long tube headers
scorpion 1.6 rockers
Howards 98215 springs
AFR guideplates
Trickflow pushrods
ARP rocker studs
Only live once I guess - trying to think if Ill need anything else...
btw, anyone heard of speedmaster pushrods?
Speedmaster PCE254.1028 is the part number... 7.2" chromoly pushrods for 51.50? I almost tried them thinking how hard can it be to make a pushrod...but went with the trickflows, cuz their name is cooler!...and ive used them in the past as well as other people have.
Old Mar 16, 2016 | 08:45 AM
  #45
ahritchie's Avatar
I'm pretty much dead set on 1.7s right now.
Old Mar 16, 2016 | 01:54 PM
  #46
trilkb's Avatar
Oh ****. Typo. I did get the 1.7s.
Scp1026's.
Old Mar 16, 2016 | 05:30 PM
  #47
BALLSS's Avatar
AFR guideplates
Trickflow pushrods
ARP rocker studs
new valve stem seals are not on your list
FelPro Viton seals will work and you should be able to get them at most auto part stores
depending on condition of valve cover gaskets...you may need a new set also
while the 7.200 PR may be the right length....given you got 1:7 RR...might want to check that length marking the tip of the valve tip with a Sharpie and turning the motor over a few revolutions by hand to see where the witness mark lands....aka check PR length
Old Mar 16, 2016 | 06:26 PM
  #48
trilkb's Avatar
Yea I just realized ill still need valve seals, header bolts (going to get some nice ARP stainless ones), and some o2 extensions and probably just get new o2 sensors and not fight the old ones.
One guy said the AFR guideplates cleared the scorpions fine too, but I definitely plan to double check everything by spinning the motor over by hand
Old Mar 16, 2016 | 07:51 PM
  #49
myltwon's Avatar
Make sure you stay away from the umbrella style valve seals if using a dual coil spring
Old Mar 16, 2016 | 08:14 PM
  #50
trilkb's Avatar
It will be a single spring with the damper removed, said to work fine. LE uses/used them that way.
Old Mar 17, 2016 | 12:48 PM
  #51
fbody_brian's Avatar
I would be really surprised if you don't have to clearance the guideplate slots, as the 1.7s move the pushrod much closer to the fulcrum and they were bottoming out in mine.
but I'm sure that with all the discussion in this thread you will be extra vigilant in checking things over.
Old Mar 17, 2016 | 02:18 PM
  #52
trilkb's Avatar
My plan was to put everything on one valve and go from there and spin it by hand, any problem with that approach?
Old Mar 24, 2016 | 04:19 PM
  #53
trilkb's Avatar
Ha my headers showed up today, guess I got a free 200$ upgrade to their catted system! I aint bitchin, first modded car Ill have thats technically legal and doesnt smell!
Also got everything else but the Rockers, which were supposed to be here the 21st, and the ebay store isnt answering my emails, so its time to go to war I guess.
Old Mar 24, 2016 | 04:28 PM
  #54
BALLSS's Avatar
yeah do that. #1 cyl would be a good candidate as you can do both int & exh. when # 1 is at TDC
just remember they are "guide" plates...not "rub" so confirm you don't have PR to guide plate rubbing on the base of the guide plate slot. The guide plates are hardened so will take some effort to grind out if you wind up having to
Old Apr 29, 2017 | 04:02 PM
  #55
95Prplppletrz28's Avatar
Curious how this turned out?
