porting tb opening while on engine?
Old Mar 9, 2016 | 08:22 AM
Justin96z28's Avatar
Default porting tb opening while on engine?
Any safe way to go about opening the TB ports from 48mm to 58mm while still on the engine? Really dont want to pull the manifold if I dont have to. But if thats the best way to go about it, then of course I will pull it...
Old Mar 9, 2016 | 09:40 AM
MonmouthCtyLS7's Avatar
I wouldn't recommend doing that. I don't remember a ported TB being that popular of a LT1 mod anyway.
Old Mar 9, 2016 | 12:01 PM
BALLSS's Avatar
IIRC the stock intake manifold opening is 54mm. you really don't want to shave off that much metal while manifold is installed on motor...shavings WILL get into motor
You can buy a 52 or have the stock TB bored to 52 (preferred) and just leave the intake manifold alone.
Old Mar 9, 2016 | 12:15 PM
hrcslam's Avatar
Who does the TB boring?
Old Mar 9, 2016 | 06:05 PM
KW Baraka's Avatar
It used to be that you could find a 'vendor' for ported throttle-bodies on Ebay.....
KW
Old Mar 9, 2016 | 06:52 PM
Casey96SS's Avatar
I have been looking for someone too. There was a pretty good listing on ebay in 2014, but it does not look like they do it anymore. It is a shame too because it sounds like a stock TB bored to 52mm operates better than any of the aftermarket ones.
Old Mar 9, 2016 | 08:03 PM
Fast350Z's Avatar
I got my stock TB ported from a guy on a ebay a few years ago. Not sure if there is still someone on there who offers the service.
Old Mar 9, 2016 | 08:22 PM
AdsoYo's Avatar
stock manifold bore is 52mm. TPIS offeres stock throttle bodies bored to 52mm and you need to send in your core. They also offer a 58mm and a monoblade.
Old Mar 9, 2016 | 08:59 PM
KW Baraka's Avatar
IIRC the stock intake manifold opening is 54mm....
Originally Posted by AdsoYo
stock manifold bore is 52mm........
No.....it's 54mm.
KW
Old Mar 9, 2016 | 09:03 PM
hrcslam's Avatar
Originally Posted by KW Baraka
No.....it's 54mm.
KW
No it's 49.265879325mm ! ........
Old Mar 9, 2016 | 09:26 PM
KW Baraka's Avatar
LOL........I stand corrected!!!!!
KW
Old Mar 10, 2016 | 05:53 AM
waltsfastz's Avatar
I donw mine back in the day on the car. Shoved some shop rags in the intake and used a shop vac to pull all the shavings out. Never had a problem
On the throttle bodies, What did they previous guy charge? Any idea where he got the butterflies? We have a machine shop, it may be something we look into
Old Mar 10, 2016 | 10:25 AM
BALLSS's Avatar
Back when I had mine bored to 52 it was David Kudos IIRC. $150
This was about 17 years ago
Old Mar 11, 2016 | 03:41 PM
waltsfastz's Avatar
Ive got a couple stock units. i may set up and work on them. Did the butterflies have a name on them?
Old Mar 12, 2016 | 09:04 AM
Yea I picked up a used 58mm TB with all sensors included on it for 80$ so I am not complaining. I just was seeing if I could do it without pulling the manifold. But it looks like I am going to pull the mani and paint it also. Thanks for the help guys. Oh one last ques, whats the best type porting bit to go about using to port it open?
