L98,LT1 and LT4
Old Mar 31, 2016 | 10:28 PM
KIngKoser06's Avatar
Default L98,LT1 and LT4
Hello friends, I understand that this site doesn't really cover the L98 engine in corvettes but I wanted to ask this because I haven't found a good solid answer. Since they all have he same 5.7 liter displacement, is there any interchangeability between these three engines? for instance, if i buy a '88-'91 C4 with the L98, could i put LT1/LT4 parts on it, like heads, intakes, cams, etc? I haven't really found a solid answer for this so I thought i would ask straight up. Any help would be appreciated.
Old Mar 31, 2016 | 10:35 PM
Catmaigne's Avatar
The LTs are reverse cooled so blocks, heads, intakes, ignition parts, water pump, etc. are all different. A lot of bottom end and some top end parts will swap between the two depending on year (rear main seal, cam type).
Old Apr 1, 2016 | 07:03 AM
myltwon's Avatar
You can bolt the heads on but they will have to be converted to conventional cooling which isn't worth the cost unless you got some bad *** lt1 heads for extremely cheap. The intake bolts onto lt1 head bolt pattern so if you had the heads on the intake will bolt on but you'll need to drill a hole in the rear for a distributor.
Many tpi guys run lt1 intake converted for the gen 1 bolt pattern and modified for a rear mount distributor because it flows about as well as the best aftermarket tpi intakes and is much cheaper.
