96 Z28 - Kooks headers
I also want to know what Kooks is describing on their website about their headers only working with their setup.
Description from Kooks website:
Must be used with Kooks Y-Pipe or True Dual System
I have the Madhammer (GMMG) exhaust on my Camaro so will the Kooks work with my setup or will I need to purchase other pipes to make the headers work?
Thanks
My review and install writeup here....
http://www.camaroz28.com/forums/exha...0/#post6905815
If you have a 2" inch drop it's going to be pretty close to the ground. Both in the SD and HD video I show ground clearance. The SD is on a flat surface, the HD is sitting on an incline.
I'm at stock ride height with the FE2 suspension option. I also have energy suspension poly motor mounts.
I did measure for someone on my garage surface one day and here is what I came up with for clearance.
Sitting in my garage, the lowest point is the cat on the drivers side at 3.5". The bottom of the driver's long tube is 4". The passenger's is 4.5" on both the cat and bottom of the header. For reference, the k-member is 5".
SD Video
HD Video
Also if you are really thinking about kooks headers call Maryland speed. They murder online list pricing if you call. I've gotten some killer deals with them on several sets.
I also bought from Maryland Speed and I had mine ceramic coated.
