LPE 211/219 Cam
and this 212/222 grind would be one:
http://elliottsportworks.com/?page_id=32
again you will need new valve springs for this or any cam. If you had your heads ported to allow the cam to perform better...even more HP & TQ. But the 212/222 would be good also with stock heads.
http://gtp-racing.com/
Advanced Induction too has done great things, however they have recently had static about the customer relations.
http://www.advancedinduction.com/
Same with that 218/224....Comp has a XE cam in their line with the same .050 duration specs, they've been producing it for well over 10 years.
If two given cams are similar in overall specs, you can bet they're going to run very similarly and produce similar results if all other factors are constant. There's not really any rocket science or voodoo about it.
