Lt1 hard start
Old Apr 24, 2016 | 08:19 PM
267kbird's Avatar
Default Lt1 hard start
New to the forum love it. Got a 97 firebird lt1 auto. Starts hard sometimes but runs fine doesn't die or anything
Old Apr 24, 2016 | 08:23 PM
hrcslam's Avatar
Check fuel pressure.
You can also try priming the fuel by cycling the key to on (not start) a few times before cranking it. If that works it's either you fuel pump or fuel pressure regulator.
Old Apr 24, 2016 | 08:25 PM
267kbird's Avatar
I guess I wondering what could possibly making it take a bit for it to start doesn't do it all the time
Old Apr 24, 2016 | 08:26 PM
hrcslam's Avatar
Again, check fuel pressure.
Cycling the key as I stated above is one way to do it without a gauge.
Old Apr 24, 2016 | 10:14 PM
267kbird's Avatar
Also unsure on how the fuel pump if working properly is suppose to sound? And yes if I prime it a couple times it's seem to pop over sooner
Old Apr 24, 2016 | 10:56 PM
hrcslam's Avatar
It sounds like a running pump. Well, now you know it's fuel delivery related. At this point you want to hook up a fuel pressure gauge at see what the pressure is with the key on engine off, and how fast it drops.
You also want to pull the vacuum line to the FPR and see if it smells of fuel.
Old Apr 25, 2016 | 08:27 PM
267kbird's Avatar
ok will tell after I do that thanks. also the other day the throttle stuck wide open wouldn't come back till I shut car off did it twice?
Old Apr 25, 2016 | 08:50 PM
hrcslam's Avatar
Time to clean the throttle body.
Old Apr 25, 2016 | 08:53 PM
267kbird's Avatar
it was weird didn't seem to have all the get up and go it usually does when the throttle stuck down?
Old Apr 25, 2016 | 09:09 PM
267kbird's Avatar
car has 267000 miles . is the FPR pretty common to go out before a fuel pump?
Old Apr 25, 2016 | 09:39 PM
hrcslam's Avatar
The only thing that can stick the pedal on these cars is a mechanical interference. Either the floor mat, the cable, or the blades are dirty. Most commonly is the blades.
Old Apr 25, 2016 | 09:40 PM
hrcslam's Avatar
No. Its usually the fuel pump. But at 267k miles, anything can fail.
Old Apr 26, 2016 | 08:38 AM
267kbird's Avatar
What would you recommend for cleaning the throttle body taking it off? Or any simpler route on cleaning the blades?
Old Apr 26, 2016 | 11:30 AM
Kcutty85's Avatar
They sell throttle body cleaner at autozone , alot easier to just remove it (4 bolts , couple sensor connectors and couple hoses ) and clean it , just watch removing the coolant hoses ,tends to want to fall on the opti .
Old Apr 26, 2016 | 11:57 AM
267kbird's Avatar
What would you recommend for a new throttle body? Wouldn't mind a bigger one if I didn't have.to go thru everything else to put one on?
