First Testing w/nitrous
Old Aug 7, 2016 | 12:30 PM
Dirty_Bird's Avatar
What shocks do you have?
Old Aug 10, 2016 | 08:57 AM
Mystery Bird's Avatar
Originally Posted by 3 window
How'd you manage 3200 on the two step? I thought you were hung up around 2500-2800? Nice work, car books!
Two step? I foot brake.
Old Aug 10, 2016 | 08:58 AM
Strange singles up front and stock original in rear. I pulled a 1.35 60ft two weeks ago but had a backfire and didn't get to finish the run.
Old Aug 11, 2016 | 12:04 AM
lt1_2buku's Avatar
What rear end are you running? You and I have similar builds.
Old Aug 11, 2016 | 03:03 AM
Dirty_Bird's Avatar
Def get some double adjustables for the rear. Normally people get the rears done and leave a bs front shock in haha
Old Aug 11, 2016 | 06:27 AM
Moser 12 bolt w/3.90 gears.
Old Aug 23, 2016 | 08:00 PM
unioncarpenter84's Avatar
What torque arm setup you running? And what hardware
Old Aug 23, 2016 | 08:05 PM
xDetroitMetalx's Avatar
Must go faster.
Old Aug 24, 2016 | 10:48 AM
UMI, short arm.
Old Aug 28, 2016 | 07:47 PM
Really and no issues with the torque arm coming loose or anything? I had a bmr tq arm and it sheared the bolts off the rear? what hardware u using?
Old Aug 30, 2016 | 06:30 AM
No problems at all, just using what ever hardware came with the TA.
Old Sep 4, 2016 | 08:30 AM
  #32
u didn't loctite or tack weld the bolts in?
Old Sep 5, 2016 | 02:50 PM
  #33
Dirty_Bird's Avatar
Umi hardware and green loctite on my 12 bolt and havent touched them since install
Old Sep 5, 2016 | 08:33 PM
  #34
hmm really yeah I've had a lot off issues broke the stock torque arm and a bmr torque arm...now i have a umi....the umi hardware that u have is it the one with the metal inserts for the bolts?
Old Sep 5, 2016 | 08:51 PM
  #35
madmike9396's Avatar
I stick with 26 tire and bump your shift point up.
What do you currently shift at ?
what tire and size are you currently using ? (Sorry if I missed it)
Old Sep 13, 2016 | 01:59 PM
  #36
I shift at 6300, bumping it up gains me nothing in ET or MPH.
Old Sep 13, 2016 | 03:45 PM
  #37
Nostang's Avatar
Mystery Bird, what cam and compression are you running in your setup?
Old Sep 14, 2016 | 06:47 AM
  #38
It's a CC XFI292 ground with a 110 LSA, 11.1/1 compression, .052 quence.
Old Sep 14, 2016 | 07:39 AM
  #39
Nostang's Avatar
Nice setup. I assume you are running pump gas. Do you have any detonation issues? What max timing are you running at WOT?
Old Sep 14, 2016 | 01:48 PM
  #40
Yes, regular 91 or 93 pump gas.
