Whats a good set heads for lt1?
ive had some of my friends ask me the same question, along with them telling me its alot easier to make 400-500rwhp out of an LS car rather then a LT car. This may be true. BUT im not too familiar with the LS motors, an ive always just seem to like the LT cars more. Ive had a total of 6 LT cars now an id like to think im getting to know them pretty well. Plus I hate the head lights in the LS cars lol
With only $5k to spend, you'd be better served doing the bolt ons and a basic rebuild. That's the only combination that you can do on that budget correctly. Yeah, you can do a 400 hp motor for $5k all day long. But when that properly setup bolt on car with the stock motor blows your doors off, you'll wish you had built your car for that power 1st.
My advice would be to build your car from the back 1st. If you know anything about Gm vehicles, it's that they have crappy exhausts and crappy rear ends. The exhaust is the last thing to exit the car, so i would start there 1st. Then I would get that 7.625 rear end sorted out. Next would be Panhard bar and Control arms. Then I would do SFCs and Tq arm. Then clutch. By the time you make it to the engine, the rest of the car will be built to handle the "400 hp" you're shooting for.
I really appreciate all the advice an options you guys have shared with me. But, I made this post while I owend my 94 z28 automatic..I want to say its been at least a few weeks now, ive now got me a 95 Z28 camaro 6speed, bought from the original owner. (Older man in his 50s) the motor has been rebuilt an gone through 14k miles an 8, 1/4 mile passes (best time from him was a 13.02 at 108.4mph)?! From what he said an had pictures of the whole process. Stock internals im assuming. Although he did change the rockers to comp. Cam 1.6 RR. (Not sure why) BBK shorties. Borla cat back (witch I hate. Going to magnaflow) an I deleted the cat....Zoom Kevlar clutch kit 1000 miles ago. B&M short throw shifter. Eibach lowering springs, KYB adjustable shocks front an back. After market red sway bars with red polyurethane bushings. Front an back. Not sure of the brand but its red an clearly aftermarket. the torque arm, cross member is like one whole peice that has a loop around the front of the driveshaft. an traction bars have been changed to aftermarket, their red as well an it looks all adjustable. The pan hard bar? (Runs from the bottom driver side rear shock to top pass. Side shock I think) its red an looks adjustable. Again not sure of the brand. I can send yall pictures. Zr1 10in wide wheels all the way around. Very deep deep tread tires. Forget the brand right off hand. The thing handles an drives amazing!! I sold the 94 an the deal with the 95 6speed 1 owner fell right into my lap the same day. But my plans are still the same. Now many of you may say im dumb for tearing apart a motor when it JUST got rebuilt not even 20k miles ago. But I still want that 400wrhp car. An now, I have a car that will handle the 400hp motor in it. So I will have roughly $5600 to let go into the "drive train" so to speak. Now if I need to blow most of that in the motor then so be it. But as I said, 1 or 2 passes is all that car will see down a drag strip just to see its best time. I dont want to build it to break it. I want to build it to enjoy it.
You may get lucky and the $5600 you have to spend could very well go very far if the bottom end is built. At the very least it should be healthy. How's the oil pressure look hot at idle and at say 6K under load? Do a compression check and post up the results. You may be a heads/cam/tune away from your goal. Then put the rest towards a 12bolt/S60/9" and have a well built car.
At the end of the day tho, screw what we all say on here. Contact LE or AI and tell them what you have and what your goals are and let them guide you in the right direction. Whether you choose to chase hp or times, they'll definitely set you straight.
you mentioned a 4.11 gear would be a good choice? Wouldnt that screw me for highway driving? My last lt1 camaro was auto. It had a 3.73 ring an gear an it rang 3k at 70mph just cruisin. I wasnt too wild about that bc I felt I shouldnt take it on long hauls (hour+ drive)
Makes sence now. Bc when im in 6th, at 70-75mph im only runnin around 1500rpms just cruisin now. Will the 4.10 or 4.11 make it more torquey in the other gears?
