have experience in building race version LT1? come in
you really made me feel happy because of your opinion
i think my bottom end needs a new set of piston rings , but the block is really healthy
my dynamic compression ratio will fall of because of the cam lobe , so i need a static CR close to 14:1 to keep the dynamic compression about 12:1
i founded speed pro -11cc pistons for about 300$ , does them have good quality ?
the water methanol can let me to use pump gas
You don't really need a big cam to make the power you're talking about anyway. I'd look for something in the mid-to-high 220's intake duration and mid-230s exhaust on a tight 108-110 LSA, with lift in the upper 500s on both sides. Such a cam would be happy paired with a static compression ratio in the 11.0-11.8 range, which is all I'd dare on questionable quality fuel, even with something like meth injection.
As far as pistons, I'd go with something like a Mahle powerpack. The Speed Pro pistons are generally heavy; you don't want to go with anything heavier than a stock piston. The stock pistons weigh 532 grams, by the way. The Mahle Powerpacks are somewhere in the range of 460 grams if I remember correctly.
What sort of resources are available to you in Persia with regards to machine work and tuning?
FTI Performance ESR Series Torque Converters ESRL8082
http://www.summitracing.com/int/part...8082/overview/
after 1-2 shift , the rpm stays about 4300 and 2-3 stays about 4800 , so i need a better 4k-8k rpm range i think
one other thing i wanna ask is that why not to go with 1.7 rocker ratio?
i'm afraid of this 4600 elevation ... that's why i want to go with a bigger lift and duration , am i wrong ?
thanks for your helping
