New heads, cam & valvetrain. Now checking PR length...Solid lifter?
Old May 13, 2016 | 11:35 AM
atlantadan's Avatar
Default New heads, cam & valvetrain. Now checking PR length...Solid lifter?
I'm installing my top end and cam soon, and the final part is the pushrod length. AFR 180's, CompCams LT3312/3314/HR112+5, ProMag 1.6's, .026 head gaskets.... I've got the PR length checker, but I'm reading conflicting reports on converting a lifter to solid for this purpose. I've got spare lifters laying around, and it doesn't seem too difficult. That being said, I read also that you should add .040 to the length due to using the "solid" lifter. Anyone?
It seems to be all over the map in regards to even using a solid lifter or a regular hydraulic lifter after soaking in oil. Then there are others that suggest using a soft spring...
I'm open to input and suggestion.
Thanks
Old May 13, 2016 | 12:28 PM
SS RRR's Avatar
Village Troll
No need when you can use this:
Not sure if it can used with 7/16 studs though, if that matters.
Old May 13, 2016 | 05:37 PM
atlantadan's Avatar
Great tool, but it doesn't tell me the length - only if ones I already have are correct.
Old May 13, 2016 | 05:45 PM
Casey96SS's Avatar
I used soft checking springs from Summit and the adjustable PR. They're cheap. It seemed like it was still a little bit of a guessing game, but it got me in the ballpark.
Old May 13, 2016 | 07:49 PM
Catmaigne's Avatar
Dry erase marker, adjustable PR, and check spring here.
Things to keep in mind...
The check spring could compress a hydraulic lifter if it's not pumped up all the way. A spare lifter converted to solid eliminates any chance of an incorrect reading.
Measuring pushrods with a caliper will not give you exact pushrod length. It will be slightly more than the manufacturer spec (my 7.150" pushrods measured ~0.020" higher).
You have to add lifter preload to pushrod length. This means preload at the lifter, NOT at the rocker stud.
Old May 13, 2016 | 08:35 PM
SS RRR's Avatar
Village Troll
Do you own a feeler gauge?
Old May 16, 2016 | 09:25 AM
atlantadan's Avatar
